A/c compressor leaking
I just got my A/C serviced and it is blowing cold, for now.
I had the shop put some dye in the system to check for leaks. Well, the compressor is leaking pretty bad and it is only a matter of time until all of the refridgerant leaks out.
The shop said that it would cost about $1000 to completely fix everything. They recommended replacing the compressor, receiver/drier, and a condenser. Parts and labor about $1000.00.
My question, other than replacing the compressor which is definitely leaking (they let me watch them work and use the light myself), how important is it to replace the receiver/drier and condenser? Neither of which showed signs of leaking.
How hard is it to replace the compressor? Are any special tools required? How do you capture the refridgerant that it in the system already? I am sure that if I replaced the compressor, I could get it vacuum tested and filled for about $100.00.
No need to replace the condenser if it is not leaking. It is a good idea to replace the receiver drier when major work is done, as it does not cost all that much, and can get troublesome if outside air gets into it for an extended period of time. You could change out the compressor yourself, and then have the AC shop evacuate and recharge the system, and save yourself a bit of money.
That was my plan. I was going to do the heavy lifting part of the work, and let the shop evac and recharge the system.
So it looks like I'll be replacing the Drier and Compressor, then back to the A/C shop for a recharge.
Thanks.
Thanks.
