LT1/LT4 Tech 1993-1997
Bought a Scanner
Old Feb 1, 2012 | 11:12 PM
numskull223's Avatar
Default Bought a Scanner
Ok, check this out and see if this is a decent scanner. I bought this one off Ebay....I hope this will work on my 95.
OTC TOOLS OTC3498 OTC Enhanced Code Scanner OBD 1 & 2 & CAN
Old Feb 1, 2012 | 11:20 PM
Catmaigne's Avatar
I doubt it. You have an OBD1 computer with an OBD2 plug so a regular scanner won't work with it. You need a laptop and one of these: OBD Diagnostics, Inc. - ALDL (GM OBD1) Cable with 16 pin Connector
Old Feb 2, 2012 | 12:19 AM
I have all the cables and software (lt1 edit) but my laptop will not connect.
Old Feb 2, 2012 | 06:28 AM
it may work, comes with the obd 2 plug and does obd1, could do the wire jump like in shbox, this one is supposed to work on a 95 its a newe model with same model numbers so not sure. NEW Actron CP9145 AutoScanner Diagnostic Scanner OBD II - Tools Hand Tools
Old Feb 2, 2012 | 07:58 AM
torque_is_good's Avatar
the web site claims it will work. The link provided by craby is to the same model scanner which I own. The 9145 works on the 95Z's and of course on OBD2 vehicles
I believe Actron has retired the 9145 and replaced it with a nicer unit but it's still pricey (i think it's the 9180 but am typing this from memory)
the 9145 fits my needs and I paid more than $160 for it. I would love the graphing feature of the newer Actron but it's not enough to make me open my wallet.
Old Feb 2, 2012 | 09:27 AM
Yeah, dang I wished Id known that before I bought this the OTC one.
Here the feature of the one yall are talking about. ebay right now for 75.00.....Dang it!
A bold step forward in DIY diagnostics! Super AutoScanner CP9145 allows the user to easily retrieve and read OBD II trouble codes and display/read live vehicle data for a faster diagnosis. This sophisticated yet extremely user-friendly tool can be used on OBD II compliant cars and light trucks (foreign and domestic) sold in the U.S. from 1996 to the present. Optional cables add coverage for OBD I 1984-95 Ford and GM models and 1989-95 OBD I Chrysler applications.
Features:
Read & erase generic OBD II trouble codes (including pending codes)
Read & erase GM/Ford/Chrysler OBD II manufacturer-specific codes
Optional cables available to read & erase OBD I GM/Ford/Chrysler trouble codes
Enables user to easily and quickly link to their vehicle
Large easy-to-read LCD screen that provides Diagnostic Trouble Codes (DTCs) and their definitions
Turn off Check Engine Light (Malfunction Indicator Lamp or MIL)
Extremely user friendly menu provides:
Monitor Status and I/M Readiness to determine if vehicle is ready for an emissions test. I/M Readiness is an excellent function to use prior to having a vehicle inspected for compliance to a state emissions program
All emission testing facilities will fail a vehicle which has the "check engine light" lit at the time of the test
Alerts user to any pending Diagnostic Trouble Codes (DTCs), and reads Malfunction Indicator Lamp (MIL) status
Built-in help screens
View live engine data parameters (PIDs)
View freeze frame data
Review data
Code definitions are stored in the tool
Ruggedly built for both shop and road test use
1 year warranty
Assembled in U.S.A.
Old Dec 27, 2014 | 05:08 PM
rs657f's Avatar
Hoping to revive this thread and get some results. I just bought an innova 3120b OBD1and2 scanner with the OBD2 plug. I have the 1995 a4 z28. This scanner doesn't work and im on a tight budget. Any other options or brands out there I can use. I saw there is a setup with the usb laptop plug in, but im not sure which route to take. Please let me know folks, thanks.
Old Dec 27, 2014 | 08:36 PM
have you tried different years or vehicle? i have to use a 92 to get mine to work on the 93. do you just want to see if there are trouble codes and what they are or are you looking to see the sensor readouts. to get codes try this with scanner on obd1. http://shbox.com/1/xraycable.jpg
Old Dec 27, 2014 | 09:56 PM
GaryDoug's Avatar
This keeps coming up in all forums I know of. The Innova 3120b will not work on a 94 or 95. One that works is the Actron CP9145, if you can find one used. Or the Actron CP9185 (new). Both are Pricey. Make sure it has the power adapter cable (cigar lighter or battery clips). Don't believe any comments about either one being only for OBD2.
See one user's response about his 95 Formula: http://www.amazon.com/Actron-CP9145-...RankDescending
If you have a Windows pc that can be placed in or near the car, you can use a $55 cable from Red Devil River and my software, Scan9495 (free).
There are options for Android devices also but are very limited, and the Bluetooth adapter "cables" cost about $80 and up.
Old Dec 28, 2014 | 12:06 PM
rs657f's Avatar
Originally Posted by craby
have you tried different years or vehicle? i have to use a 92 to get mine to work on the 93. do you just want to see if there are trouble codes and what they are or are you looking to see the sensor readouts. to get codes try this with scanner on obd1. <a href="http://shbox.com/1/xraycable.jpg" target="_blank">http://shbox.com/1/xraycable.jpg</a>
<br />
I have the 95 so it takes that obd2 16 pin plug with the obd1 scanner. I just want something basic to read the check engine codes
