LT1/LT4 Tech 1993-1997
big problem car dead?
Old 02-23-2008 | 04:07 AM
kyleb's Avatar
Default big problem car dead?
damit guys another problem right after i put in the heater hoses to!!!
i was driving home from jack in da crack and all the suden my car jut shut off!! i dont know if it made any noise or not cause the music was on but when i went to start it again it just cranked and then tons of smokke came outta the tail pipes!!! it was so much smaoke i took off acros the street for a few moments thinkin it was on fire~~ when i got home with it...(towed it) i tried to start it again and itcrankd foreverand then began to start barely and it would it at a realy shty weak idle like it kept wanting to die off so i shut it off hella fast i cant remembr any smells right now but the white clous outta the tail pipes im ure is a good clue for somone
if any one can help me out here man this sux life has been so gay lately u have no idea!!!!
thanks for any help from anyonein advance
Old 02-23-2008 | 04:21 AM
MassholeLT1's Avatar
Default RE: big problem car dead?
lots of white smoke generally means a bad head gasket- but I am surprised that you wouldnt see any smoke at all, then see tons all of a sudden....
Old 02-23-2008 | 04:33 AM
kyleb's Avatar
ive been reading that and also that it could be an internal coolant leak?? i hope its not a gasket meybe pete will chime in on this one
well this is gey cause i stil owe 2k on it meybe ill sell it for that much and get another car this i so gey
a couple of days ago i did have the wrong heater hose in and is blew coolant al over the engine...
Old 02-23-2008 | 04:51 AM
6v49der's Avatar
Well, what did the smoke smell like? You had to have smelled something... Were all the guages reading in their normal areas? Any time something bad happens to your car take a mental picture, or have a post it note pad and pen your car wink wink to write down important info you might forget, camera/video phones help too.
I digress, the white smoke is definitly indicitive of something not functioning properly, and generally white smoke + coming out of exhuast = blown head gasket.....
Old 02-23-2008 | 04:58 AM
kyleb's Avatar
im thinking it was smelling like coolant now that i think about it lol and i did try to camara phone it but it was so dark it wouldnt work happend at like 12 midnight
Old 02-23-2008 | 10:30 PM
kyleb's Avatar
ok the car did start and stayed at an idle and the pipes were dripping coolant out of them. it stayed at a normal idle but after the car got warmer it satred spewing so much white smoke out the exhaust. i then tryed reving it up and then it bogged and wanted to die. then a little bit after i started hearing a curdle noise under the hood so i shut it off the noise sounded like sand in yer teeth er somthing and it souded like it was around the fuel rail area meybe ioll try to post a vid of the car if my fone will let me
Old 02-23-2008 | 11:02 PM
kyleb's Avatar
here are a few pics
in one of the pics you can see the ground wet with coolant under the pipes...
[IMG]local://upfiles/3349/56E13BBD65D8426FACEB8401B7B71C42.jpg[/IMG]
[IMG]local://upfiles/3349/C05D3506F1CA46B083E793561F5FF3D0.jpg[/IMG]
[IMG]local://upfiles/3349/D65151E2BE5F4DB1A6AFB122170AFDF2.jpg[/IMG]
Old 02-23-2008 | 11:28 PM
I would say a head gasket blew, may also be a bad manifold gasket, but that is unusual. A compression test will definetely tell you.
Old 02-24-2008 | 12:04 AM
kyleb's Avatar
wow this must be a big problem if pete is iffy about it lol jk... ummm ok how can i get it copresion tested? or is there a way i can do it myelf? also either way it looked like a new engine or a rebuild is needed right?
coolbeverage
08-25-2014 01:23 PM
JustGreen
05-15-2013 07:06 AM
Opticon
04-29-2009 02:33 PM
zklt1roland
07-06-2006 12:37 AM
Quick Reply: big problem car dead?
