Best way to replace the Opti?
Any suggestions? I dont have a lift, just jack stands.
You don't need a lift. I did mine in my garage with nothing more than a few jack stands and a floor jack. Check out http://www.lt1engine.com/tech/93-97-...emove-replace/ it is what I used as a guide when I did mine.
A: locate your teenage son
b: tell him to do it seriously it's not bad at all but.......and I mean BUT have you had the car for a while and know well its' history? If not go buy a timing cover gasket kit as it comes with all 3 seals for the timing cover as well as a couple new o rings for the waterpump and opti if you haven't yet, get some new spark plug wires and a set of plugs. The $40 jegs 8.5mm wires are fine as are NGK tr55's for $2 or so each at adv auto you'll need 2 gallons of coolant (not pre mixed) water pump gaskets get a new accessory belt if it hasn't been replaced buy a can of brake parts cleaner buy a can of MAF cleaner if you don't have long tube headers, plan on the entire day for the job because the spark plug wires are a bear if you have stock exhaust manifolds drain coolant jack up car place on jack stands remove radiator hoses and continue to drain coolant disconnect CAI ( you do have a CAI and not the stock air box don't you?) remove fan assembly let coolant continue to drip into your eyes remove accessory belt let coolant drip on you remove balancer remove water pump remove optispark check the 3 seals. best case, replace the waterpump and opti drive seals and carefully check the crankshaft seal. Hopefully the crank seal is bone dry so you don't have to remove the hub. Or, skip replacing the top 2 seals and let them leak all over your new opti in a few months and you get to do this again; the choice is yours. install new opti If you have stock exhaust manifolds, please pay attention to the next step. If you have long tube headers, please skip the next step and continue below go get extremely drunk, absolutely hammered, zonked, ****faced....... remove and replace spark plug wires and plugs while under there, clean off all the sludge and muck from the underneath of the engine with brake cleaner. Don't get too nervous about the drip on the flywheel cover, that's just a leaky rear main seal (try a bottle of white shepherd rear main sealer before dropping the tranny to get to that seal. No, not Lucas, White Shepherd, and it must be "rear main sealer") re-install waterpump replace balancer install fans install hoses( you may want to replace them) clean MAF install new belt reconnect everything if you have stock exhaust manifolds please pay attention to the next step go find a friend or close relative to kick you in the butt for being so cheap as to not have long tube headers. After replacing the plugs and wires you now know why the rest of us keep saying to put on long tubes |
Originally Posted by Grandpaswagon
(Post 444582)
Sure wish I would have put them on mine. Got in a hurry and went cheap on that, was afraid of ground clearence too.
I am the teenage son. Only had my car a week so I dont know the history yet. But what I was told is that some lady had it. Its completely stock, except the clutch I put in.
ok tig you just told a teenager to go get wasted and work on a car. lol great writeup though. chip dont drink until your married,,, lol. get your dad to do the drinkin for ya and he may just put the plugs in for ya. 95 is a vented opti so opti is sealed to the front cover instead of the shaft seal like a 93-94
Originally Posted by xXChipXx
(Post 444618)
I assume that you understood the humor about getting hammered. it is to emphasize the point about the plugs and wires. They are an absolute bear to do with stock exhaust manifolds. But, do go under the car, do clean it up and look for any drips and try white shepherd if you have a slight leak in the rear main seal. Also, heed my advice about the seals |
