Best cam to install?
I'm restoring my LT1 1997. I will keep engine quite original but want to upgrade to a better cam shaft. Seems to be hard to find. Any suggestions? Please ad links to your suggestions.
More info about my car www.projektcamaro.se |
Cam choice is based on a lot of factors. There is no best CAM. What is better? better gas mileage? Better 1/4 mile time? Better top end max HP? Better low end torque out of the whole? That is 4 very different CAMs.
you might try one of these from elliotts. then when you want more you wont have to go any farther than the heads.
212/222 .563/.562 114 LSA 218/224 .570/.565 111 LSA |
please understand that if you change to a cam with more lift that the stock one you will need to upgrade your valve springs and retainers.
I found that GM hotcam may be perfect. No mods needed and all included in a cam kit. Any idea where to buy this cam kit for best price (and service)? RockAuto doesn't sell the cam. I live in Sweden and have to order from a US webstore.
Originally Posted by aaberg
(Post 664260)
What about this cam kit: COMP CAMS PART #K07-304-8. Is it a better replacement than LT1 hot cam kit? Read more at
http://www.ebay.com/itm/COMP-CAM-CHEVY-LT1-LT4-266-276-500-510-XTREME-ENERGY-HYD-ROLLER-CAMSHAFT-KIT-/181116667488?pt=Motors_Car_Truck_Parts_Accessories &hash=item2a2b650660&vxp=mtr#ht_2827wt_1161 What I want from the cam kit is good idle and mid range Power. No need for racing etc. |
