battery guage pulses
I noticed the other day when I was sitting a stop light and I had my vent on that my battery guage would drop down. I turned it off and it went back up but it pulsed, like moved up and down. what could be causing this to happen, maybe the alt? Thanks all
akohnz
akohnz
Nope. I was on the highway yesterday, driving this time, and I put my windows up and turned on the just the vent and my battery needle went down. Then I turned the vent off and it went back up. My battery guage normally sits right above the middle white line, but when the vent or anything to do with the AC/heat until is turned on it drops to right below the white line. Thanks
akohnz
akohnz
Thanks for the reply Pete. Is there any way to check the alt to see if its bad? If the stock one is having hard time handling the load then should I upgrade to a higher amp?
akohnz
akohnz
using a volt meter crank the engine and put the red lead on your positive battery post and black on the negative. it should read about 14 volts. less than 13 but more than 12 it's probably going bad. less than 12 it is dead. also auto zone will check it for free but, you will have to remove it. sick
Its not the battery, it cant be I just replaced the thing about a year and half ago and the previous one had been in there for 3 years I had it since I bought the car from a private seller. I think the opti's goin out too, what do you think about the redesigned one that MSD put out???
akohnz
akohnz
Thanks Pete. Do you or anyone else know about the new MSD redesigned distributor? Here is a link for the one I was looking at on the internet, its the silver one. I called them to confirm that it would fit, but I was just wondering if anyone else has tried this, is it junk? I have one of those unfortunate camaros that has a problem keeping a distributor, and I was looking to get something that would fix that problem. Thanks
http://www.jegs.com/webapp/wcs/store...tegoryId=25253
akohnz
akohnz
