Bad issue, very scared
eh well, heres everything
ABSinop light is randomly on and off (Flexi wire?), speedometer does not read correctly (wheel speed sensor?)(ive searched these)
and today my alternator died, before i owned the car it was used in stereo competitions which i guess was the cause to it giving out? it was melted a bit around the positive hookup.
i buy a new alternator slap it in and try to start the car and nothing, no bing noise no starter click, no lights, no radio, battery has a decent charge btw
so i go to unhook the battery again and check things out, unplug everything (alternator, everything connected to the battery etc.) and as i go to hook the battery back up a spark arced about 2 inches from the positive to the battery and a puff of smoke came from the alternator, frying the brand new one.
i gave up after that because i really hate getting electrocuted and had it towed home
help? this car is my baby
Hey Phalen
The only thing I can lend some advice to is the abs. Check the 3rd brake/spoiler. You may have a bulb out. I just bought a 95 Z and am in the process of ressurecting her from the dead. That has been one of my many probs. Good luck with the alt.
so it sparked when you hooked the positive wire to the positive terminal? check the junction box to see if its grounding to the body. its a small red plastic box on the passenger side fenderwell. check any hot wires for the stereo or amps. better get the ohm/volt meter out and get to work.
That's it. It is on the passenger wheel well on my '94. It should not be loose. If it is, that would be one of the very first things that I would fix. All of the power runs through that junction.
7T3Z28
South
08-03-2012 06:10 PM
The_Bandit
10-21-2011 11:46 AM
