LT1/LT4 Tech 1993-1997
Abs light is on.
Old Dec 12, 2010 | 12:08 PM
  #21
layzurguy's Avatar
This wiring Diagram, http://shbox.com/1/relay_for_ss_spoiler.jpg , shows exactly what to do. Just get a plain automotive relay to wire in right behind the spoiler tail light.
Old Dec 14, 2010 | 01:30 AM
  #22
ThisGuy68's Avatar
I found a relay in a parts car, but it measures about 1 inch per side. There is nowhere I can wire it in the third brakelight, I believe it's an aftermarket SS clone spoiler and I don't want to drill it. As I'm writing this, I'm pretty sure the wire for the brakelight runs directly to the battery so if that's the case, I will just wire the relay into there. Otherwise where would I want to put it?
Just so I don't sound so clueless I want to point out that I just bought the car and it was a trade in so I had no communication with the previous owner. It would be great for something this easy to turn my "abs inop" light off though.
Old Dec 24, 2010 | 06:06 PM
  #23
ThisGuy68's Avatar
Ok, so I just popped out the kicker panel looking for the wiring and realized it runs right under the gray plastic piece on the hatch. Guess that answers where I can fit the relay in. Found the wiring joint right away. Put both wires into their respective sides of the relay. ABS inop light is still on. I should note that I still notice some of the LED's are out and the red light(not in the tail light) are out. Just wondering if the LED's are out( and the rear side light), will that keep the ABS inop light on? By the way, I do hear the relay click so I know it's working.
On a related note, I found that the fuse wired and ran separately under my hood is somehow related to my ASR light being on. I took the hoop connection off of the battery and the ASR button functioned as it should. It of course doesn't work anymore now that I taped that wire over to prevent it from shorting. Just weird.
I have the battery removed now to try and see if that will reset it. What's everyone think?
Old Dec 24, 2010 | 06:07 PM
  #24
most systems and lights are ground switched so hot is hot all the time.
Old Dec 24, 2010 | 08:46 PM
  #25
ThisGuy68's Avatar
Well i hooked 85 to ground and 86 to positive. Is that what you mean by hot is hot(positive)?
Old Dec 24, 2010 | 09:41 PM
  #26
lol,,, yah sorry bout that. positive is hot all the time on most systems and the ground is switched. also fix the lights first just to be on the safe side.
Socom
Nov 9, 2013 01:41 PM
Rent
Apr 22, 2013 11:08 PM
hpd218
Aug 24, 2010 12:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
dustinb
Oct 1, 2007 06:58 PM
