96 lti transmisson ?
I HAVE A 1996 Z28 AND JUST HAD THE TRANSMISSION REPLACED IN IT AND NOW IT CANT SEEM TO MAKE UP ITS MIND IF IT WANTS TO BE IN 2ND OR 3RD AND OVER REVES IS THIS U THINK A ELECTRONIC PROBLEM OR JUST A BAD TRANSMISSION
Sounds like a bad rebuild or messed up installation. In a proper rebuild it is common practice to replace all the electrical stuff in the transmission, such as shift solenoids, control solenoids, TCC solenoid, etc..
Double check the tranny oil level, make sure its warmed up and idling in park. Mine did the same thing after i replaced it, and i filled it, drove around the block, checked the level again and it needed more fluid. Did this three times before it finally pumped everywhere inside and was actually full.
Travis_216
10-20-2013 04:36 PM
