LT1/LT4 Tech 1993-1997
95 camaro emissions fail
Old Dec 23, 2010 | 12:51 PM
antcamaro's Avatar
Default 95 camaro emissions fail
i have a 95 v6 3.4 and it keeps failing due to emissions, high hc ppm's and co levels, it also fails for high and low idle.
i have done: cat,egr valve,o2 sensor,cleaned the throttle body, throttle sensor, tune up.
is there anything else i should know or do?
Old Dec 23, 2010 | 12:56 PM
BasicConcepts's Avatar
Technical User
go to a different shop 95 and older should be exempt from emissions
Old Dec 23, 2010 | 01:02 PM
^ Not in all states.
Old Dec 23, 2010 | 01:04 PM
antcamaro's Avatar
I'm in NJ, the car drives good other than the pull or lag
Old Dec 23, 2010 | 01:05 PM
Technical User
ohhh... learn something new everyday
Old Dec 23, 2010 | 01:06 PM
Up until a couple of years ago, IL was 1968 and newer had to get tested. 96 and newer was plug and play, 95 and older got the dyno/sniffer test. For some reason, my 69 wouldn't pass.
Some states still require older cars to get tested.
Old Dec 23, 2010 | 01:11 PM
Technical User
and here brand new cars dont have to be tested theres not even a visual emissions test
Old Dec 23, 2010 | 01:12 PM
Here too, till they are over three years old.
Old Dec 23, 2010 | 01:14 PM
antcamaro's Avatar
this all has nothing to do what i posted about. i was looking for help in fixing it
Old Dec 23, 2010 | 01:15 PM
Technical User
no emissions at all here just a safety test every 2 years
