LT1/LT4 Tech 1993-1997
94 z28 rims ?
Old Apr 23, 2011 | 11:37 AM
jpkz94's Avatar
Default 94 z28 rims ?
hey im lookin to swap fronts to the back but a friend said ofsets were diff and that ill have to take tires off the rims to do so? true or no?
Old Apr 23, 2011 | 12:07 PM
what rims are they? so long as there stock there all the same.
Old Apr 23, 2011 | 05:34 PM
ThisGuy68's Avatar
If they're corvette rims, a lot of them are different front to back, but as long as they're all the same size (all 15 inch, all 16 inch, etc.) and matching, they have the same offset. That is not to say that all tires of the same size have the same offset, but if it's 4 of the same rims in a set, with the same tire diameters, there would be no reason for different offsets unless it's a mismatched set. The stock salad shooters are all definitely identical and 100% do not have different offsets. Even if they're aftermarket, the offsets shouldn't matter front to back as long as they're made for your car, that is how some people have tires sticking out far beyond their wheel wells. I assume this is just rotating the tires, so make sure to follow the recommended pattern(sometimes it's diagonal). I wouldn't bother if it's because the back tires are bad because you need the better tires up front for handling. I suppose that is just personal preference though.
luciora
Apr 12, 2010 08:18 PM
keith197431
May 29, 2009 07:34 PM
spisak
16
Nov 13, 2008 08:16 PM
94 z28
16
Feb 24, 2008 02:31 AM
90blackrs
Nov 25, 2007 11:20 AM
