94 z28 opti spark ?
[:@]where can a guy get the socket for the cap n rotor im guessin about a e1 socket and to do just the cap i should only have to pull the balencer right ???? any help would be very helpfull thx
[IMG]local://upfiles/1930/6BCD8CD42304491ABEDB2FF9E5FFC973.jpg[/IMG] |
RE: 94 z28 opti spark ?
http://www.charm.net/~mchaney/optisprk/optisprk.htm
Quote from website: "The unit is held together with inverse (male) Torx screws. The easiest way to remove them is to get an old Torx screw out of something and hold the screw with vice grips. You can then fit the screw over the head and turn it. All screws have been removed in these photos to make access easier. " Lisle tools also makes a set of very small torx sockets, but the walls are too thick to fit into the hole, but you can grind them down to size |
:D thx man spent all day sat trying to find a socket
In addition to pulling the balencer, you will also have to pull the water pump and air pump.
