CNCman |
11-05-2009 06:58 AM |
94 Z28 Lt1 Turns over but will not start ?
Last week I changed the oil and took it out for a couple of hours around town with no problems, no SES, no missing, it ran like a top. I got busy around the house and it set for two days. Got ready to take a Sunday drive and it would turn over but not start. I have changed every sensor, ICM, coil, Opti, plugs/wires, with GM parts except the MAF. Scanned the PCM ( no codes ), changed the PCM back to the original factory spare one, and still no fire with the timing light. Fuel pump is working too, you can smell a little gas after turning it over at the tail pipes. I had the VATS disabled on the re-programmed PCM, and it does have an aftermarket alarm system installed, but it will not turn over if it's not unlocked, so im guessing thats OK as well. I was going to check all the wires for ground and bad connectors, but I did that when I put the rebuilt engine in a few weeks ago. Any one ever had a simular problem, I sure miss the Z running ??
:icon_bricks:
