-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   94 z28 (https://camaroforums.com/forum/lt1-lt4-tech-9/94-z28-38016/)
ddgds03 Apr 28, 2009 12:49 PM
94 z28 not firing
Ok guys got a good one here. i have a 94 z28 with the lt1 in it i just replaced the water pump and the distriputor with new cap and rotor put everything back together and fired it up after a few tries. then killed it and let it set for about an hour then fired it back up pulling it out of my shop and it just died and will not fire up. checked for spark and i have no spark at the coil. what might i need to do to get spark at the coil. i also do not have spark at the plugs either. thanks
whammer3024 Apr 28, 2009 01:48 PM
optispark is shot...probably get wet when your water pump went out...change it and it should be good to go
ddgds03 Apr 28, 2009 02:06 PM
just put new opti in when put the water pump in.
whammer3024 Apr 28, 2009 02:38 PM
sounds to me like it has to be something in the opti...where did you get it?
ddgds03 Apr 28, 2009 03:50 PM
i got it at auto zone about a week ago. it worked fine at first then when i went to move the car it died on me and i cant get it started back up because of no spark.
whammer3024 Apr 28, 2009 04:26 PM
i'm still going to have to say its the opti...just because a part is new doesn't mean its good...ya know? that's where i'd start anyway
