94 camaro to trans am interior swap
ok so ive searched and searched but havent found answers....i have a 1994 z28 m6 camaro my question is will a 94 trans am dash swap out with my car? will the ac still work and the vents line up? also will the speedo and other gauges work the same? how much wiring will i be looking at? and how many hours will this install take in your opinion? any help will be GREATLY appreciated
I haven't seen any info on this forum about that swap. It sounds cool, the pontiac interiors are nice and I think would look good in the camaro. Your best bet would be to get a 94 t/a donor car because you will probably need all sorts of little things that the dealer will have to get and just in case the hvac is different or the wiring. Have you tried a google search? Good luck I would like to see if it can be done.
its a f body, the outside has some differences but the inside should have the same measurements. like u said the hoses for the ac and some things like that may give u fits.
I know the 97 T/A is much different than the 95 z if that helps. the vents are in different place and the dash is totally different. I like the T/A interior much much better. no more rattles and stuff. it really seems much tighter and stronger. the doors espclly are much stronger.
yes ive tried google and havent found much.....i have srumbled across some old car domain pages of guys who did it tho. it looks really clean and modern to me in comparison to our current set up
it wont be hard to do on your car,it didnt work out for me because i dont have an obd1 car.all you will need to do is get a wireharness for the new gauges and just splice them in.you still will need the firebird a/c ducts or it wont work
ok yah thats what i figured with the harness... it will probably be a little time consuming but worth it. what i meant was after the new ducts are installed will the air blow out of them but i see now that it will...thanks for all your help btw :] your car is a 93 right? i thought those were obd1 cars as well?
