93z28joel
93z28joel
hey man last time you gave me a good advise about my heads im still getting mix oil with coolant me and my dad work on the car he took care of one head and i took care of the other one...im not sure if i killed it in the first place, but the first bolt itight it all the way
and torqued the bolt with out tighten the other ones i heard they suppost to go in 3 passes u think this is causing the problem or how can i test the head to see ifthey're craked without removing it ...if anyone else has any suggestions let me know...
by the way is a 95 z28
RE: 93z28joel
I will leave this message up due to forum issues with PM's right now, but in the future please send the member you are addressing the question to a PM instead of making a new post about it.
Thanks,
~95slvrZ28
Thanks,
~95slvrZ28
RE: 93z28joel
ORIGINAL: 95slvrZ28
Thanks,
~95slvrZ28
Thanks,
~95slvrZ28
The forum issues should clear up pretty soon...
RE: 93z28joel
[sm=headbang.gif]
Why are you yelling at me? PM's aren't working right and that's why this thread is still here, I stated that in my first post. If they were working right this thread would have gone to the magical land where all dead threads go. There is no reason to yell at me. I'm not even argueing with you, hell, I'm agreeing with you..
To give you a little answer to your thread, just because I'm a nice guy...pick up a Chiltons manual about engine overhaul and retorque your head bolts in the pattern and torque adjustment suggested by the manual. Hope you didn't crack a head...
RE: 93z28joel
see noz.... when they give peopel that neat moderator tag they ummmm kinda sorta... have to moderate....now under normal circumstances.... what you did break the rules....i know i know pms arent working calm yourself......however see what slvr did is remind you of the rule .... say that you were fine in this case... and moved on with his day....your the one now creating a issue...i know know....your twiching like a hampster on herion to say pms arent working....and if you had been sternly warned you might have a case but the fact of the matter is
he didnt.....but yes lets hope you didnt crack a head cus id hate to see a camaro engine go down due to sombody overreacting and being stubborn.....
