-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   93 z28 power windows? (https://camaroforums.com/forum/lt1-lt4-tech-9/93-z28-power-windows-65336/)
chad kennith Oct 7, 2011 10:19 PM
Well only my passenger side window will roll up, and only with the drivers side control switch. The switches that do not work fill like they have no tension like the one that works. What does this mean, that the switches are broke? Has this happened to anybody else? Thanks.
craby Oct 8, 2011 09:44 AM
6 Attachment(s)
yep i would say the switch is broke.
Attachment 23504 Attachment 23505
Attachment 23506 Attachment 23507 Attachment 23508 Attachment 23509
chad kennith Oct 8, 2011 11:04 AM
Okay thanks. Is my best bet getting those off Ebay, or from a junk yard?
craby Oct 8, 2011 11:56 AM
you can get switches that fit pretty easy, 93 to 97 fit. ebabe or check these places
RMS Automotive Supply, LLC - Keeping your ride on the road!
GM Parts Direct: Your direct source for Genuine GM Parts
thing is the 93 is the only year to have yellow lettering and graphics on its switches and knobs so white is common and yellow almost impossible to find.
grabbem88 Oct 8, 2011 12:17 PM
One way to find out is pull them put and see if the tabs are broke. I used a jewlers screw driver for a while until I gound some at a junkyard. Kinda scarce unless you find a v6 model cause most people pass those right up
