93 Z Won't start
93 Z28, turn ignition and dash wakes up, turn to start and nothing. Starter is fine, changed neutral safety switch and ignition switch. Cleaned all wire ends and nothing. I am stumped. Any ideas??
Security lamp lights when you try starting??
2 Attachment(s)
turn switch to run and security, SES, Check gauges, and ABS INOP lamps are on. Turn to start they stay on and coolant level lamp comes on.
pete hit it. security light most times means vats is acting up. may want to bypass it.
vats bypass and more. click/look at 25 and 25.5 here https://camaroforums.com/forum/93-02...62/#post557634
Still workin on starting issue. Trying to avoid vats bypass. Thanks for the input.
