93 A4 ECM for 93 M6 car??
I need to replace the ECM in my 93 and found one from a 93 A4, and was wondering if it would work?? I know the idle speeds will be different. But would anything else?? Also would a ECM from an LT1 M6 corvette work?? Thanks
you can get the 93 A4 pcm retuned for the M6 talk to the guys from pcmforless.com and they should be able to help you
yeah you can hook it up,but you will need it tuned
Will i at least be able to put it in and drive to a shop? Also who is a good shop around the denver area??
PM slvr hes from that area,yeah you you will be able to drive it but the idle will just be off
| All times are GMT -5. The time now is 09:54 AM. |
