LT1/LT4 Tech 1993-1997
383 stroker full build
Old Jun 20, 2010 | 02:20 PM
CammedZ28's Avatar
Default 383 stroker full build
Alright so I'm about to trade my car for a 93 z28. The trans is built, and the engine is built and is now a 383 stroker with a port matched LT4 intake with stock LT1 heads but ported as large as they can go, so the seller says.I've never built an engine before, so I have a few questions.
How can I tell if all this has really been done without firing it up or tearing it apart? He's got the car almost fully together, but it needs an optispark, injectors, and a bigger fuel pump. How much power can I expect to make with this motor? He said it's built with keith black pistons and all forged eagle internals, 1.6 aluminum roller rockers ect ect.
I'm a noob when it comes to building engines, and I'm kind of weary of buying it while it's not running. But if it is what he says it is, it's going to be one hell of a beast.
Old Jun 20, 2010 | 02:56 PM
reciepts? what shop balanced the stroke? who did the porting?
Old Jun 20, 2010 | 03:59 PM
383Stro's Avatar
I have 34# injectors, and a gm opti, the fuel pump should be more than adequate- call me if you are interested in either of those 2523425779-Wiley
Old Jun 21, 2010 | 08:53 AM
z28rob18's Avatar
well if he has no reciepts then you'll have to look under the valve covers see if there is aluminum rockers wen you get a chance drop the pan and check to see if they r eagle rods and cranks. i forget if there marked where you can see though. the heads you cant tell if the cam is small it may be hard to tell. you cant tell if its been bored out
Old Jun 21, 2010 | 10:46 PM
CammedZ28's Avatar
I'm not worried about it anymore, he's producing invoices and receipts for all the work so that makes me feel alot better.
As far as the suspension and rear end goes, everything is still stock. What do you guys recommend I do to accommodate for so much power? So far the motor and trans are built, its got dynotech lt headers w/ true duals, aluminum driveshaft...
Old Jun 22, 2010 | 10:47 AM
z28rob18's Avatar
get a 12 bolt or 9" and never worry about the rear again
Old Jun 22, 2010 | 11:16 AM
Old Jun 22, 2010 | 11:25 AM
z28rob18's Avatar
yea you'll def pay for it but it'll save u money and hassle in the long run. id look into midwest chassis fab 9" they had a great price wen i was looking and also have nice suspension pieces to go with it for low $$
Old Jun 23, 2010 | 07:53 AM
CammedZ28's Avatar
Thanks guys!
383strokernos
Jul 25, 2012 06:56 AM
JunctionBoyz
Aug 24, 2011 12:27 AM
us63bravo
Jan 28, 2010 10:04 AM
1bad96Z28
Jun 24, 2007 11:41 PM
