383 build
383 build
so i just wanna know what kinda numbers you guys think this will put down when i drop it in...it has an eagle crank, ealge rods, srp forged pistons, 1.6 rr's, melling hv oil pump,gm hd timing set,gm847 cam,new lifters,ported lt1 castings,comp springs,new valves,updated vented opti and timing cover,ported intake, lucas 42lb injectors, LT's, BBK 58MM TB and 7 liter oil pan.
This is going through a Yank 3600 stall thanks for any replies.
