-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   3000$ performance build (https://camaroforums.com/forum/lt1-lt4-tech-9/3000%24-performance-build-64224/)
dogdog130 Aug 20, 2011 10:56 AM
i got 3000$ to put in my new lt1 with a auto trans what would u spend it on
craby Aug 20, 2011 03:01 PM
good stereo is a must, good brakes, tires, wheels, lights, good cat back exhaust, cai, headers, and i think money is gone.
dogdog130 Aug 21, 2011 09:41 AM
was meaning internal can u really do much for 3000$ i want to rebuild the engine and company that doing it going to put in performace parts in free just have to get them
timmyz28 Aug 21, 2011 11:15 AM
For $3000, if you shop around and find good deals, you might be able to pull off a good top end build, but that's a big if because it gets pricy and adds up quick.
x01660 Aug 21, 2011 02:41 PM
If you can do the work yourself, get LE2 heads and a cam, headers, a tune, fuel pump, injectors and upgrade to C5 brakes if you have 18" rims, or LS1 rotors if you have the stock wheels. And if you have enough money, beef up the rear end because it WILL detonate...
Good luck and kill Rustanks!!
x01660
craby Aug 21, 2011 10:02 PM
check here http://www.elliottsportworks.com/ for the le2 heads and cam. you will need 1.6 rockers, push rods, lifters, i would suggest that when you order from lloyd let him know what you want, he is very good and will give you an idea of what you will need to go with the heads and cam. then its a matter of finding the best deal.
dogdog130 Aug 22, 2011 09:16 AM
Yea im trying to get money in the thing bec i am doing motor then trans then rear before even thinking about turbo or super chargeing it
