-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   3.73.... 7.5? or 8.0? (https://camaroforums.com/forum/lt1-lt4-tech-9/3-73-7-5-8-0-a-61171/)
clay95z28 Apr 21, 2011 01:21 PM
alright so i'm planning on getting gears, 3.73's. wat size diameter do i get? 7.5 or 8.0? wats the difference?
timmyz28 Apr 21, 2011 08:36 PM
Moser Engineering Ford 9" Rear End | 1993-2002 F-Body Camaro Firebird
Not sure about what diameter to run if you just want gears. But if you want a whole rear that can handle a lot of power, this link should help you out.
Buffalo02Z28 Apr 21, 2011 08:37 PM
I'm pretty sure that your rear is a 7.5.
craby Apr 23, 2011 10:13 AM
yep 10 bolt 7.5, whats in the car, you need the carrier for the 323 or higher to work with the 373s
clay95z28 Apr 23, 2011 02:35 PM
basically im just planning on buying gears and a rebuild kit. i got a 6 speed. So I can go ahead and order the gears with a diameter of 7.5 an i'll be good?
blackz87 Apr 23, 2011 02:57 PM
10-bolt gear sets will be listed as 7.500/.625 dia and depending on the ratio will require a 2 or 3 series carrier. What gears are you running now????
clay95z28 Apr 23, 2011 03:04 PM
its all stock in the rear end. manual 6, i believe theyre 3.42's in there now
blackz87 Apr 23, 2011 03:56 PM
"I belive" when buying parts is not the best method . So what is it???
craby Apr 23, 2011 04:01 PM
if you havent done a rearend rebuild before i would not suggest you do it. just one misstake (the list of possible misstakes is not short) and the rearend is toast in a short time. get good gears or they whine.
Camaro 69 Apr 23, 2011 05:35 PM
Going from 3.42's to 3.73's isn't a very big jump, not worth the expense in my opinion. Another option is putting on smaller diameter tires. Changing from your 25.7" diameter tires to 24" will give you the same result as the 3.73 gears would with your current tires.
