3.73.... 7.5? or 8.0?
Moser Engineering Ford 9" Rear End | 1993-2002 F-Body Camaro Firebird
Not sure about what diameter to run if you just want gears. But if you want a whole rear that can handle a lot of power, this link should help you out.
if you havent done a rearend rebuild before i would not suggest you do it. just one misstake (the list of possible misstakes is not short) and the rearend is toast in a short time. get good gears or they whine.
Going from 3.42's to 3.73's isn't a very big jump, not worth the expense in my opinion. Another option is putting on smaller diameter tires. Changing from your 25.7" diameter tires to 24" will give you the same result as the 3.73 gears would with your current tires.
