1995 z28, opinions on upgrades and tips will be greatly appreciated
the air foil does not do alot. there is a vortech elbow that i am using, it has sort of an air foil in it.
http://www.percyshp.com/Seal4Good.html
i would use the gm performance opti
ok, ill look into that elbow, thankyou. so abs light turned on now. used cars are such a gamble, bought it for 4500 but im stick with it. is it safe to drive if the opti sucks,,it takes two cranks to turn on now, speedometer is wobbling and shows wrong speed now. is that all opti also? the car has 80,000 miles.
f your a lt1 guru please add your 2 cents. this is my first car, i have steady income to fix/upgrade (military)
thanks
thanks
the stuff i pour into my gas tank, and the stuff you put in with your oil when you get an oil change, i cant remember either of the names( i have recepts, i just to lazy to look) but i did research to get the ones that accually work
