LT1/LT4 Tech 1993-1997
1994 z28 suggestions
Old 09-22-2011, 06:51 PM
DiggityDavee's Avatar
Default 1994 z28 suggestions
I have a '94 z28 has the lt1, automatic tranny, has a shift kit and a little stall in it, the motor has been chipped so the shift point have been changed along with the rev limiter has been set at 6500 rpms, it has 411 gear in the rear end, bought my car like that couple weeks ago. cold air intake moroso, it has the flowmaster 3 inch catback exhaust with nice
chrome tips ,it has a new grant steering wheel. give suggestion on how to change it and what i should do with the car i like speed so ya..gotta beat the mustangs around even tho it should already, but ya suggestions would be nice
heres a video of me doing a short burnout...dont listen to ppl in vid...wondering why my car makes these noises when i do this: http://www.youtube.com/watch?v=98uFbrgqjXw and sometimes black smoke comes out of exhaust as well when i do burnout
Old 09-22-2011, 09:14 PM
torque_is_good's Avatar
sounds like someone's engine has a miss
Old 09-23-2011, 06:12 AM
what does that mean? btw im a tard when it comes to vehicles....lol
Old 09-23-2011, 07:19 AM
grabbem88's Avatar
Not good tagging the rev limiter!
Old 09-23-2011, 08:47 AM
stock lt1 is not setup to be reving to 6500. what chip are we talking about? 94 is not set up to be tuned using a chip. you have to send the computer in to be tuned or tune using aldl cable.
Old 09-23-2011, 02:59 PM
i didnt do it and idk what to do so ya..
Old 09-25-2011, 02:51 PM
ok so should i sell this car and try buying a stock looking one and build onto it?
idk seems to be easier to do. if so what year do you suggest? im not rich by no means lol
Old 09-25-2011, 05:12 PM
you need to learn more about the car you have. let see a picture of the engind compartment and a few various areas of the engine like each side so we can see. look for anything that doesnt look stock. the video sounds like your reving till the limiter starts messing with the spark or the limiter/chip is failing.
Old 09-26-2011, 01:39 PM
mloaks's Avatar
1996 or later, something with OBD II
Old 09-26-2011, 02:19 PM
Catmaigne's Avatar
I'd avoid OBD2 cars. You gain another catalytic converter (complicates header install), two O2 sensors (post cats), an EVAP sensor to crowd the passenger side of your intake manifold, and a nagging PCM you can't fiddle with for cheap.
I have a friend with a 95 Z28 (OBD1 computer with an OBD2 connector). He uses a $60 ALDL-USB cable to connect his PCM to a laptop for easy scanning/tuning, that way he can get live data without paying for an expensive scanner.
Quick Reply: 1994 z28 suggestions
