LT1/LT4 Tech 1993-1997
Cruise Control Stopped working?
Old 05-01-2009, 01:40 AM
AmirGTR's Avatar
Default Cruise Control Stopped working?
Is this a common problem? It was working a while ago, it doesn't any more. How can I fix it?
I know there's always that anti-technology guys that come out and say "well just dont use it then" but trust me, cruise control is the only thing that can actually keep my heavy foot off that pedal.
Old 05-01-2009, 01:45 AM
Saint_Ali's Avatar
is the abs light on or flashing ?
Old 05-01-2009, 01:51 AM
AmirGTR's Avatar
It used to do that. Not anymore though, it's been a while.
Old 05-01-2009, 01:55 AM
Saint_Ali's Avatar
cause the abs and cruise control are wired into the same circuit so if you have an issue with one you probably have one with the other,and if you dont use the correct bulbs in the tail lights,that also can create a problem
Old 05-01-2009, 01:56 AM
AmirGTR's Avatar
so what do I do?
Old 05-01-2009, 02:01 AM
Saint_Ali's Avatar
make sure all your bulbs in the tail lights are correct and working properly,check your fuses
Old 05-01-2009, 10:43 AM
AmirGTR's Avatar
The tail lights work. How do I check the fuses?
tonybabb
08-24-2012 05:51 AM
ZedNorth
10-26-2011 01:14 PM
shinwolf14
09-29-2010 12:39 AM
Nite
09-13-2009 07:07 PM
81zedder
05-31-2008 11:12 PM
Quick Reply: Cruise Control Stopped working?
