LT1/LT4 Tech 1993-1997
1993 and 1995 O2 Sensor Question
Old Sep 17, 2011 | 08:59 PM
kierantjones's Avatar
Default 1993 and 1995 O2 Sensor Question
I recently did a engine swap with a 1993 to a 1995 LT1 engine and was wondering if i could use the 1993 O2 sensors with the 1995 engine? or will i have to get new ones? i heard the 1993 O2 sensors werent heated and the 1995's were. Thanks!
Old Sep 17, 2011 | 09:04 PM
correct you can use either 02 sensors, if you use heated you will have to wire power to them. i did the change to heated on mine.
Old Sep 17, 2011 | 09:07 PM
i mean that i am using the 1995 engine and harness, etc. but i can use either heated or non heated sensors? what's the difference?
Old Sep 17, 2011 | 09:25 PM
the heated ones dont foul so easy and put the computer into closed loop earlier. save gas and plugs if your rich at first startup. other than that they both use just one wire to provide the computer with info. are you using the 93 computer? you will have to use the 93 harness if you are.
Old Sep 17, 2011 | 09:55 PM
No we transferred all the 95 harnesses and i mean ALL of them. So the heated O2 sensors are better?
Old Sep 17, 2011 | 11:45 PM
JGuy07's Avatar
Yes, if you can you should run heated O2's.
Old Sep 18, 2011 | 12:11 AM
^^^ agree heated are better. you may need to have a 95 gage cluster. what transmission are you using?
Old Sep 18, 2011 | 12:20 AM
We are using the 6 speed.
Old Sep 18, 2011 | 12:27 AM
keep us up to date on how it goes.
Old Sep 18, 2011 | 12:30 AM
alright will do. were still working on getting it to run. it was a big job! were going to try to get it started tomorrow will keep you guys up to date and ask questions if needed!
