%$#%& seatbelt light stays on
[sm=badbadbad.gif] seatbelt dummy light stays on when the seatbelt is plug in. How do you bypass this to shut this damn light off?????
RE: %$#%& seatbelt light stays on
About four months ago, I had exactly the same problem. I never found the indicator shutoff, but it was definitely an electrical problem. When my car refused to start a month later, I replaced the coil, and the seatbelt light problem disappeared.... Good luck
there is a wire harness where the seatbelt bolts to the floor under the drivers seat just unplug it
if that doesnt work ground it to the seat bolt |
