LS Series Tech 1998-2002
x-pipe
Old Oct 17, 2006 | 11:35 PM
00camaross's Avatar
Default x-pipe
Im jsut starting wiht learning more about my car but do they even make w-pipes for camaros? All I see are y-pipes.
Old Oct 17, 2006 | 11:36 PM
00camaross's Avatar
Default RE: x-pipe
I meant do they even make x-pipes sorry
Old Oct 17, 2006 | 11:44 PM
JD1969's Avatar
Default RE: x-pipe
No. The car does not have enough cleance around the rear end/suspension to run true duals over the rear axel. You can get an X pipe with dumps, but it is very loud and is not technically legal. Not to worry though, a good 3 inch y-pipe and cat back will flow enough to support at least 425 rwhp
Old Oct 17, 2006 | 11:54 PM
00camaross's Avatar
Default RE: x-pipe
O ok that helps out a lot. Do you know of any good y-pipes or do they not make a difference? What about headers what are some good makes? Should i get longtube heads or something else?
Old Oct 18, 2006 | 02:53 AM
02CamaroV6's Avatar
Default RE: x-pipe
if i put a y pipe on my V6 would it do anything?
supafly147258
Aug 31, 2011 12:16 AM
pockets47
Dec 8, 2008 04:17 PM
rockin85
Jan 20, 2008 09:24 PM
sp9o3
Aug 20, 2007 02:20 AM
JHL88
Apr 23, 2007 09:00 PM
