TC Help?
I'm new to the camaro andLS1, and was wondering what the best stall would be. I plan on putting in the PRC stage 1 heads and a magic stick 4 from TSP. I'll be adding all the other mods at the same time like a new intake, headers and true duals.
Somthing in the 4000 rpm area will get you the best performance. I run a Yank SS4000 with a 2.5 STR. My cam is little smaller and I have stock heads, my best time is in my sig. You should be able to run well into the 11's. Look into Fuddle as well, they make good converters and are pretty reasonable on price.
ORIGINAL: nickdotcom
jd, you still on the 10-bolt?
