Seafoam
Ive heard of people using seafoam in there car. Ive seen on youtube that it makes white/gray smoke coming out what is that from? i also heard it is bad for your car. can anyone fill me in on what its like, if its good for ur car and all that happy stuff? thanks
When ussed right seefoam is a great tool. It cleans sensors, vacuum lines, injectors, valves, and other intake and fuel system parts. When i sea foam any vehical i add about half the bottle to 2-4 gallons of gas and use the rest in the vacuum lines. The key is to find a line with good vaccum and just sip the cleaner very slow. This will of course make the engine run a little rough and kick out a little smoke. Once you add the rest of the bottle or you kill the engine let the vehical sit for 5-10 minutes then start it get it to idea down a bit, then drive it like you stole it untill the smoke stops and the car runs smooth again.
I have had some good results using sea foam and stronly recomend using it every year or so.
alright thanks. i wasnt sure on exactly how to use it.. still kinda confused and nervous because i hear it can be harmful if not done right? i might try it on my other car first to see if i do it right... and how long will it take to make the white smoke go away
man, read the directions, I been using SEAFOAM for years , never seen white smoke, never had a problem using it. Its not a miracle drug, but it will help, I say help clean injectors, carbs, lifters etc..
