Rear End Gear Ratio
If your planning on changing gears your probably wasting your money b/c those stock 10 bolts are ****. I dont know what GM was thinking by putting those in there. You should save up for either a strange 12 bolt or nine inch or a moser 12 bolt or nine inch. Im working on getting the moser nine inch with 4:10's
10 boltsCAN be built to take alot of punishment. I know a guy running hi 9s on his. if you have the means, I suggest a 9 inch, if your means aren't quite that good, then a 12 bolt. if you're on a tight budget, massage the 10 bolt if you can't find a used rear.
