Plugs for my 01 SS
Stay away from the E3 and Plat +4 from bosch. GM recommends using iridium plugs that run about $6.99 each. OEM was NGK/AC Delco Iridium. I would put either Autolite Iridium or NGK iridium in the engine. If you cant afford that then go with Autolite Double Platinum.
Massey
Massey
I just run coppers, no difference really. At moment got champions gapped at like 0.38" I think, you can run anywhere between 0.3 to 0.6" im not an expert but some run hotter or colder, ie like N2O or not. For a better idle, go with the smaller gap. Previously had NGK TR5s too or TR55 are good
ive used the tr55 and bosch +4 and both have worked fine. i am using a msd coil so i figured the +4 would do fine and did. only thing that would work when i was running ridiculously rich.
i use NGK V power and for ls1's heard alot of people recommend these plugs. in the end everyones gonna tell u different stuff and honestly they all are good and as long as your not running nitrious it dosent matter to an extreme degree at all
hoursetraitor
04-25-2011 10:14 PM
