LS Series Tech 1998-2002
PLEASE HELP 85mm or 90mm
Old Aug 9, 2010 | 10:08 PM
  #21
libertyforall1776's Avatar
^ Do not descreen -- you are just asking for troubles...
Don't just hack up a nice car. Anyone can be a hammer mechanic -- it takes skill to do things right.
Old Aug 9, 2010 | 10:37 PM
  #22
Cam02ss's Avatar
You usually descreen when you get tuned. If done properly, removing the bottom of the air box is not a hack job. Unfortunately, there are the cases where people should have left well enough a lone.
Old Aug 10, 2010 | 11:31 AM
  #23
DarkKnight's Avatar
GTO Killer
LimeKnight
i have done all the free mods that dont require hacking... my car is a race car as well as daily and i am trying to keep the value up, at least for now, just in case because im only 20, anything could happen, ie. i did ones like the throttle body one, re route the hose around tb and plug tb, that could be reversed for w.e reason but did make a good dif on the air temp after the tb, im not planning on changing out my ram aim slp intake that i have right now, its got a k&n filter in it and theres alot of people i know running the same thing that are pulling tens... so its obviously a decent setup, the tb size enlarge is to prepare me for the cam this winter, and i get PLENTY of air to support an 85 right now according to my mechanic, the question was is the 90mm worht it? at this point i dont think so
Old Aug 10, 2010 | 12:52 PM
  #24
Cam02ss's Avatar
If you were going to port the LS6 intake to match the 90mm TB then yes, it would be worth it. If not then go with the 85.
