LS Series Tech 1998-2002
Oil leak
Old 03-31-2017, 11:06 PM
Ennisdavis23's Avatar
Default Oil leak
I used the uv dye. Not coming from slot in bell housing. Its dripping from the starter bolt up high on engine. No oil from heads up. Drips down the joint between engine and belhousing. Some of the cross main bolts look wet but this starter area is dripping bad. Any ideas?
Old 04-02-2017, 12:14 AM
oil pressure sensor/switch, common leak spot, sensor fails and leaks. otherwise i would look at the rear intake seal but i dont hear much on them leaking in the ls1
Jelz28
07-18-2012 06:01 PM
cazador64
03-13-2006 01:22 AM
Quick Reply: Oil leak
