cam specs
Does anyone know the specs on the stock camshaft for a 2000 SS?
RE: cam specs
http://www.smokemup.com/tech/ls1.php there you go and some others just in case.: 1998 - 2000 Fbody 202/210 int/exh @ 0.05" duration 0.496" / 0.496" int/exh lift 116 LSA 2001 - 2002 Fbody 197/207 int/exh @ 0.05" duration 0.467" / 0.479" int/exh lift 116 LSA 2001 LS6 cam 207/217 int/exh @ 0.05" duration 0.525" / 0.525" int/exh lift 116 LSA 2002+ LS6 cam 204/218 int/exh @ 0.05" duration 0.551" / 0.547" int/exh lift 117 LSA |
| All times are GMT -5. The time now is 05:37 AM. |
