Autometer Tach install .?.
where would i find the ingintion control module on my 02 SS im trying to put in an autometer tach but i don't want to go through alot of wasted steps to do so. So if somebody has done this before and could let me know I'll really be a happy camper........thanks
RE: Autometer Tach install .?.
You just splice into a wire under the hood on the passanger side from the main wire harness, I think it is a white wire and the wires should be listed, if I remember right it is 35 on 98 models or 10 on 99 or newer models it's a white wire, I am not 100% sure I did this like 7 years ago =/
You have to set the tach to run 4 cylinder mode because the ls1 sends a different signal than a regular v-8 , I did it before with an autometer tach before. Good luck
