LS Series Tech 1998-2002
2000- z28 Tune up? noise
Old 10-02-2009, 02:56 PM
auto's Avatar
Default 2000- z28 Tune up? noise
just got a z28 102k miles, want to give it a tune up, what do you guys recommend? oil types? plugs? also im hearing a clunking noise when i go into bumps and holes from the front right side, the wheel doesnt shake when i drive, any ideas?
Old 10-02-2009, 04:00 PM
strut mount lose, ball joint, a arm lose or bushings bad. spark plugs are about all there is to a tune up. 10w30
Old 10-03-2009, 08:51 AM
maudyZ28's Avatar
Just make sure you have plenty of time to do the plugs and the back too on the passanger side are a nightmare of a job, and be careful not to snap any!
You could also change the plug leads if they have never been done, and the air and fuel filter, diff oil and gearbox oil if you wanna go all out
Old 10-03-2009, 10:32 AM
auto's Avatar
what type of plugs do you recommend? i plan to change motor oil, tranny oil, plugs, gas/air filter brake pads and cut the rotors i talked to a mechanic friend of mine, and he said its not nessecary to change the rear end oil for now. car has 102k miles.
another thing, i checked what was making the noise, the wheels have no play what so ever, but the bracket what holds the front sway bar look like it snapped apart, so i did a quick weld patch job, any where i can get this bracket from? other then the dealer?
thanks!
Old 10-03-2009, 11:06 AM
maudyZ28's Avatar
ok, for the broke part i link you mean the sway bar drop link, the big bolt with the bushes that attaches the sway bar. Ebay, UMI, hotparts.com, etc. There cheap too, go for the polyurethane ones if you have the cash.
You dont have to do diff oils, but for the sake of $45-60 you might as well do the whole lot, just undo the axle over, drain it and throw 2 quarts? in
Plugs are NGK TR55 or TR6, some people take about gapping them further, but there are usually pre gapped and pcm adjusts stuff anyway. But is important to check there similar to old one
Old 10-03-2009, 11:12 AM
auto's Avatar
hah, i wish it was the bushing, but it literally is the bracket that the sway bar bushing is bolted to that connects to the frame that is snapped, i guess the power of the beast
Old 10-03-2009, 11:18 AM
auto's Avatar
another thing i want to do is clean under the hood and engine bay, any products are good/safe? i had a bad experience once when washing under the hood.
Old 10-03-2009, 11:19 AM
maudyZ28's Avatar
on the lower A arm? next to where the strut bolts in??
Salvage yard is best bet in that case, as long as it wasnt in a front end smash
Old 10-03-2009, 11:27 AM
auto's Avatar
yes i believe its that, its shaped like an A or and upside down U
Old 10-03-2009, 11:28 AM
auto's Avatar
just got off the phone with a speed shop, they dont recommend those ngk plugs for my camaro since it has aluminum heads
this might be the ultimate newbie question but, since mine is a z28 that means i got the ls1 right?
Quick Reply: 2000- z28 Tune up? noise
