want some headers
Old Mar 31, 2009 | 09:01 PM
sickwithit's Avatar
Default want some headers
What up guys,
I have a 02 camaro ss and I want to put some long tube headers on it. The problem is I live in California and I have to smog the car. I was told that if I keep all my smog equipment I should be able to pass smog with the long tube headers. Has any body tried this set up and if so did you pass smog?
Thanks
Old Mar 31, 2009 | 09:10 PM
PAzYearazzUP's Avatar
Sick? I am going to ask you a question and it is going to sound stupid is guess where it came from is you guessed it. Don't laugh cause, I'm "StuckWiTitoo!"
Say, I keep my emissions on. Say that reads out the pipe and the sniffer has my 02 and N0x us odor. Say, we take a vacuum cleaner handle extension and stick it up the exhaust tip.
Here is the stupid question: Will the sniffer change the numbers if the vacuum hose is now a few feet back? Sea, eye told chew it was stew pit.
Old Apr 1, 2009 | 11:26 AM
evilkal's Avatar
You're a moron. This has nothing to do with what he asked.
OP: I'm not sure about the Longtubes... Pacesetters do wonders I've heard and I do believe they pass emissions. I'd call Pacesetter and ask them if the long tubes will still pass emissions. As long as you still have all your other emissions equipment on the car, you should be just fine.
Old Apr 1, 2009 | 03:46 PM
My B-inn-Law is a musician, and I call most musicians morons.
If you had a trombone and extended the tubes, did you change anything about that breath blowing the same air?
Only a moron would think you add more pipe the emissions change. Fuel is a set BTU. How did you change the BTU is already spent and now it took longer to reach atmosphere is a split second or less.
I'll make you look azz stew pit is azz stu pit does. Is man, if you could not follow the practical said two different ways is I am locked in a vacuum and cannot get out of the absolute air speed you jack in the box wit extra azzauce.
Old Apr 1, 2009 | 10:38 PM
95slvrZ28's Avatar
Paz, I need you to stop using words that are simple misspellings of common profanities, they are not tolerated on this board, thanks.
Second, when you put long tube headers on because it moves the O2 sensors farther away from the source and therefore it takes them longer to heat up to an operable state. This in turn makes the car run in open loop mode for longer and will effect the emissions data.
To the OP: If you have headers with all the emissions fittings and a catted Y-pipe you will be able to pass smog. Unfortunately for you long tube headers are specifically illegal in California, you cannot run them and pass your test. Even if you pass the smog test you will fail the visual inspection with long tube headers. Buy a good set of shorties, unfortunately it's as good as you can get.
Old Apr 2, 2009 | 01:17 AM
Slvr, I do not need to expose my tuning tips is all on you, fella. You groupthink for everyone else is you cannot read the factory service manual, can you? I can tell by how you talk the walk. Watch dis.
You did not lengthen the car to a limo. No matter even still. The 02 has it's own heat source so it knows heat wise is electrical mode is already working. That means you could place the 02 anyplace. Will the fuel seep through the pipe or will it travel out one hole is the only way out is how the 02 reads is it is preheated [look it up if you are going to discuss loop in detail]. Dude, how does the morning choke stabilize if not the 02. Did they shut down the analog too? Are we open loop or closed loop or a combination of both? 02 sure is running analog as soon as you turn the key on she warms up to 0 to 5.0v.
Be ever so careful speaking high tech fuel injection steps or I am going to spit codes in you soup is alphabet soup tell me how to post the tech fella is you have a problem, not me. Open a FSM once inn awhile tell me how to type it out.
WOT slvr is saying is that your californay sniffer is it sniffs outside the exhaust pipe is weeps out the fitting or something is misinformation galore is how long has this been going on, slvr if you and I are having book conflict is you do know this is OPEN BOOK 101.
zNever give me a waring about anything, dude. You can wallow in the tech you have posted is we sure are having an education here is same chit wear out ever I go is not too many can grasp the basics I guess?
NOT MY FAULT EITHER!
Old Apr 2, 2009 | 01:31 AM
95slvrZ28's Avatar
I agree Paz, the emissions data once the car is warmed up and the O2's are at their operating temperature is not going to be altered due to long tube headers. The law that Cali passed was done before heated O2 sensors became common and it's stuck until today. In Cali they do a visual inspection as well as a "sniffer" test. If you have long tubes you immediately fail the visual inspection, this is only in Cali and NY at the current time. Where I live you have to pass a visual inspection, but they just inspect to make sure you're running a cat. (by the way, wideband O2's are from 0-5V, standard 3 wire O2 sensors are from 0-1.1V, guess this adds to a little more misinformation eh?)
Oh, and you just expended your final warning...thanks.
Old Apr 2, 2009 | 02:36 AM
SpecterGT260's Avatar
Ninja Administrator
longtubes will trip the SEL on most cars due to faulty temperature readings. I have had this happen on my own vehicles. in california an SEL is enough to fail, not necessarily only the sniffer. Therefore you should look to midranges.
paz, ur not making sense, and you are giving bad tech using faulty logic.
stop it
Old Apr 2, 2009 | 01:25 PM
sickwithit's Avatar
thanks to everyone who posted a helpful reply.
Old Apr 2, 2009 | 03:29 PM
evilkal's Avatar
Take out your O2s then measure the AFR... Wanna bet against me or you wanna just hurry up and shut up?
primo_1976lt
70-81 V8 Tech
Sep 2, 2010 01:52 PM
broncojr_8907
Jun 19, 2010 03:48 AM
sPaC31
Jan 14, 2008 06:43 PM
myTreadZz
Oct 31, 2007 10:24 PM
2fast4u
Jun 4, 2007 08:34 PM
