Is this real? 3.8 Turbo kit.
Well, stock 3800 Series III engines did 269 HP w/supercharger from the factory...
http://en.wikipedia.org/wiki/GM_3800_engine#Series_III
But yea, it looks like you're probably right, based on the internal upgrades on the Series III 3800...
i understand that but a 3800 block with stock internals is gunna start having troubles after about 9-10 lbs of boost.... sooooo if its for stock engines then its not past that, and if its not past that then its not 200hp gain, now if it said max hp gain was 200 at 20psi, that i could see but you would require a decently built internal setup
