Help With air intake with ram air hood!!!!
Old Mar 29, 2009 | 04:03 PM
Tomplayer105's Avatar
Default Help With air intake with ram air hood!!!!
Ok I have a 97' Camaro RS with a SS ram air hood. I want to put an air intake into my car, or a cold air intake. I cant find a intake for me car. Will I not be able to have one because of my Ram air hood??
Old Mar 29, 2009 | 07:20 PM
whammer3024's Avatar
ROTM Winner
so its an aftermarket hood? you aren't actually using the ram air? if not, then a cold air intake isn't a problem at all. doesn't use the hood. if the ram air is functional, then its just as good as a cold air intake
Old Mar 29, 2009 | 07:42 PM
yes it is an aftermarket hood, actually its just like yours if yours is functional. And how much hp do you think the functional ram air hood has added?
Old Mar 29, 2009 | 07:54 PM
PAzYearazzUP's Avatar
ZERO.
Ear is WHY. You tell me if the engine is sucking in more than WOT ram can push up against the back of an intake valve is where is the popcorn icon?
http://www.youtube.com/watch?v=ffEaCSHyRYg
I question those mechanic experts around the neighborhood is ram my hood due dee two shoes.
Old Mar 29, 2009 | 08:31 PM
ROTM Winner
not sure why you think a functional ram air hood doesn't add any power? explain...in english
Old Mar 29, 2009 | 10:11 PM
In plain English...
If I have a vacuum sucking thousands of times as in times, 8 cylinders. Did you see how the needle sucked more than what ram could push? Did you see that when I lifted, I pressured the ram on lift? For every action is an opposite and equal?
In other words, I am moving over 100mph and I am sucking in more air than what the air speed I am pushing into >to create a quote, ram effect< is it will not produce double the suck of the engine.
Therefore, to have a ram effect, I need to first match what air is being sucked in at speed, where I would have to double 14.7 to 28 pounds of push. First I match the suck of the vacuum. Now I can push with the other 14.7psi is the pressure behind the intake valve is ram it in dare... You go in plain english.
Old Apr 11, 2009 | 07:55 AM
tman21786's Avatar
Paz still lost me with all that.. but all i have to say is that i had a stock hood on mine then changed to the ram air(not an ss ram air though) and i can say that i did notice a difference in power when i was on the highway.. couldnt tell ya how much but i could feel it
Old May 5, 2009 | 08:01 PM
HaloJDawg's Avatar
I'm definitely NOT taking paz's side, but from what I can decipher of his esl (thats english as a second language...) posts...is that he's saying with 8 cylinders already sucking in so much air...you have to be going really fast to match that, then even faster in order for it to help(push enough air into the intake to make a difference)...therefore giving you more top end power...i don't know why he couldn't explain it like that...
Old May 5, 2009 | 09:33 PM
YoungDriver's Avatar
I think in plain english he's saying:
As your car is driving, your engine sucks in air to the 8 cylinders. Your car is moving, so it's sucking in the air it's being pushed into. With Ram Air.. it suggests it can push MORE air in. He's saying that there isn't any EXTRA air that your being pushed into. So there's not enough air in front of you to be sucked in, making it physically impossible to push more air in your engine. The video shows the needle is not moving, there is no extra air being pushed into the engine, therefore Ram Air does NOT work.
I think that's the gist of it.. haha or I read that completely wrong.
Old May 28, 2009 | 01:04 AM
jjz28's Avatar
If it didn't make more power, The ss camaro would have the same hp as the regular z28. I think ram air is not only about the forcing of air but also the cooling of it. I'm sure there is more power.
