71 camaro vin decoded
hello i was wondering if any of you 2gen Camaro guys can help me out decoding my vin on my 71 Camaro
vin# 12487IN562246 |
Only thing it tells you that you don't already know is that it is an original V8 car and it was built in Norwood,
1st- 1 GM 2nd- 2 Camaro 3rd- 4 V8 4th&5th- 87 Coupe 6th-1 Year 71 7th- N Norwood (plant location) 562xxx Seral number (IMO you should not post your hole Vin number online. No one needs to know the Serial numbers and it could be used to track your car.) I do not pretend to know how someone could use it against you I only know a PI can find out everything about you based on your vin assuming your title is filed with your State. If a PI can do it I am sure a scammer can also. . If you want more details you want to decode you trim tag (AKA Cowl tag) https://www.chevy-camaro.com/chevy-c...ecode-1971.php "The trim tag is riveted on the driver's side of the cowl under the hood." |
| All times are GMT -5. The time now is 09:11 AM. |
