Transmission help.
Transmission help.
Ok so i am putting a new setup in my car, motor, transmission and rearend. I am wanting to go with a T-56 transmission but im pretty sure those are hydraulic cluthce's. So what i am asking is, what all would i need to do to put the T-56 in my 75 camaro, hooking it up to a 68 model 350 motor?
RE: Transmission help.
your trying to replace an automatic with a standard? if this is the case your looking at alot of modifications and alot of work. your best bet would be to find another second gen junker body that has a standard setup and swap the parts that away. the main things that you have to setup is the pedals, the hydraulic lines , slave cylinder and crossmember. good luck. sick
dsinclair999
02-21-2011 11:24 AM
