Tire size
Old May 27, 2007 | 09:53 PM
Eric89RS's Avatar
Default Tire size
I have a 89 camaro with 8 in rims on the back and im looking at getting tires this week and i need an answer if these will fit or not. I am looking at the 275 50 15 street et tires. I need to know if they will fit or not or if i should get a different size.
thanks
Old May 28, 2007 | 04:28 AM
8485Chevycowboy's Avatar
Default RE: Tire size
i take it they r 8in wide if so yes , if i rember right they will hold up to a 295, but make sure the tire will not be rubbing on the inside wheel well and the outside wheel well. the type of rim u have may also be a facter, I would check before u leave the tire shop,check the clearinces on the inside then as well bounce ur rear shocks make sure there is no contact with the tire or u could spend more money buying another set of tires.
Old May 28, 2007 | 08:40 AM
Eric89RS's Avatar
Yes they are 8 in wide on the back. I was just wondering if any one had them one thier camaro before or not. I think that i can make them fit on the inside by pushing the metal in but i dont want them hanging out. The whole reason i want these tires is i want the most tread i can get on the back and only have them 26 in tall .
Old May 29, 2007 | 01:04 PM
1969 SS's Avatar
you are really going to lose some of your handling. anything more than a 255/60 on that rim, you are going to get a lot of sidewall ballooning. a tire of that size should almost go on a 9" - 9.5" rim
also if you try to roll your quarters to make them fit, you are going to ruin your paint. even if you actually use a the proper roller, you are probably going to crack your paint
Davila2000maroRS
Apr 27, 2011 05:13 PM
68SS/RS
Aug 22, 2010 05:28 PM
kstoll99
Sep 27, 2009 11:13 AM
bd92rs
Aug 7, 2009 09:04 PM
DUB C
Feb 11, 2008 07:03 PM
