side vents on a 79
side vents on a 79
Im restorin a 79 Z28 and i was wondering if the vents on the front fenders did anything or if they were just for looks. and if they do do anything can u open and close them.[&:]
RE: side vents on a 79
They are not very functional due to no direct air support to the engine compartment. If you could cut the fender and modify the wheel wells, you could make it a lot more effective. As far as me, I'm just putting it in and hammering the wheel well down notcing it and running tubing into the engine compartment. I'm also going to buy a fiberglass hood that has heat extractors. You can also modify the wheel wells at the bottom to become brake coolers.
chris.langlais
10-13-2011 01:31 PM
