remote program
RE: remote program
[align=left]Matching Transmitter@)To Your Vehicle[/align][align=left]You can match a transmitter to as many different vehicles as you own, provided they are equipped with exactly the same model system. (General Motors offers several different models of these systems on their vehicles.) Each vehicle can have only two transmitters matched to it.[/align][align=left]To match transmitters to your vehicle:[/align][align=left]1) Find the Data Link Connector (DLC). It is in the bottom of the instrument panel near the steering column.
2) Insert one end of a fused jumper into terminal 8. Terminal 8 is the top terminal on the far right.[/align][align=left]3)Insert the other end of the fused jumper into terminal 4[/align][align=left]4)Terminal 4 is the fourth terminal from the left in the top row.[/align][align=left]You have now grounded the program input line. You should hear the door locks lock and unlock within one to three seconds.[/align][align=left]When matching transmitters, the first transmitter code matched will be stored in both memories until a second transmitter is matched. This means that the second transmitter will not work until is matched in step 5.[/align][align=left]Press any button on the first transmitter. The door locks should lock and unlock.[/align][align=left]5) Press any button on the second transmitter. The door locks should lock and unlock.[/align][align=left]6) Remove the fused jumper from the DLC.The system[/align][align=left]7) Check that all the buttons on both transmitters work correctly.[/align][align=left]The system will not work unless the jumper is removed.[/align][align=left].[/align]
