radiator help
My car runs a little hot with the stock rad that is probably original to the car. 84' also just swapped to a 350 slightly built. I found a local radiator shop with a all aluminum 2 core. SILLA brand. payed to much for it from what i can tell but that's another story.
should I even bother with installing it as if i put fluid in it i cant take it back. will this help any thing at all over stock. it is thinner than my stock one is as well. SILLA OE REPLACEMENT RADIATOR, 2-ROW -- 26.25 in. x 17.25 in. x 1.37 in. core size, 2-1/2 in. x 18-5/8 in. top header, 2-1/2 in. x 18-5/8 in. bottom header, 1.3 in. inlet size, 1.6 in. outlet size; Engineered and manufactured under the highest quality standards; Effectively boosts engine functions; Distinguished for outstanding, reliable and efficient performance; With lifetime Silla limited warranty. Condition: New Warranty: Silla's Limited Lifetime Warranty Part Number: SILLA0918-2 here is a ebay listing that has my part number correct. |
Most likely your old radiator is partially clogged, and a new one will probably fix your problem.
You must buy new one to fix all the issues which occurs now. Surely your problem will be solved.
