Problems w/ '98 V6 camaro
My '98 V6 has recently had a new radiator installed... but I'm still having problems. The tempature gauge jumps around usually getting very hot and the heater only blows out cold air. I can hear the fan come on so I know that is working.Right before the new radiator was installed I had everything flushed and cleaned, filters replaced, new water pump, etc... I need to get a smog soon and I'm scared it's not going to pass! help! Any suggestions of what could possibly be wrong would be much appreciated.
Thanx! -Christina |
RE: Problems w/ '98 V6 camaro
Sounds like it's air locked. Seems like mine did the same thing, and I had to fool with it by letting it get hot and opening the radiator cap to get the air to move to the resevoir tank, but mine is a v8 but the principle should be the same. You might just have to mess with it for a while.
Thanx, I'll give that a try and see what happens
