oil pan
oil pan
Last week I had my oil changed, the mechanic told me that the plug was bad and I should probably either replace the whole pan or atleast have it rethreaded. Anyone know about the price difference between the two and if a it would be better to just get a new one than fix the old?
RE: oil pan
is it leaking? if not dont worry until next time you change the oil. rethreading is a do it yourself job. just go to an automotive store buy you a "tap" of the same size and when you unscrew the drain plug and all oil is out just screw the "tap' into the whole and out again then pour in a fresh quart of oil let it run out inspect plug for cross threads if all is good repalce plug fill with oil change filter and your back in buisness. its probably just cross threaded. and a "tap" will fix it.if that doesnt fix it you are only out a couple dollars and you would be cheaper to replace oil pan than to have someone remove pan, drill bigger size hole, and re-tap.
RE: oil pan
Don't bother with a helicoil it won't stay in, unless you're dealing with an aluminium pan. What year is your car? Later F bodies used a 12X1.75 plug w/ a rubber oring seal. I did oil changes at Wal Mart for 10 years, don't laugh they paid me $11.50 an hour 40 hrs. per for it, I have fixed a few. These oil pans are pretty tough the plug will almost always strip before the pan gets screwed, because people overtorque the plug and stretch the threads. All you have to do is chase the pan with a 12X1.75 tap and install a new plug and oring. go to Wal Mart, they'll probably give you the plug you need. The earlier model GM's used a standard fine thread plug, I had that in my K20. When it stripped, I taped it out to the larger late model Ford/Chrysler plug, can't remember the exact size I'll have to go check and get back to you. This alows you to retain a factory size plug that is easier to comeby and any oil change facility will have onhand incase it should ever need to be replaced again. Not everyone stocks the standard oversize or double oversize "pan saver" plugs
